Sponsored by: CARiD
P030300 Help!
Old Jun 3, 2020 | 04:24 PM
cemass86's Avatar
E200 c207 1.8 cgi
P030300 Help!
Hi, i have e200 1.8 cgi engine shaking....
P030300 misfire in cylinder nr 3. I have checked coil is ok and spark plug is ok, but still the same misfire on cylinder nr 3! Any ideas? think about injector. The car have 100000km
Old Jun 4, 2020 | 11:33 AM
konigstiger's Avatar
'71 Pinto
https://www.autocodes.com/p0303_mercedes-benz.html
Old Jun 4, 2020 | 11:47 AM
Mud's Avatar
Mud
2011 E-350 4Matic Sport
As K showed, resolve the setting criteria for the code. You need compression , fuel and spark in the right amounts and timing for successful firing.
When a cel sets it also captures freeze frame data - look at that for anomalies.
You said spark is ok - don't take this badly but how did you check and verify?
A good scantool can show run data as well as injector pulse width. If you or the shop has an oscilloscope, a relative compression test is quick and easy.
You have to work through the 3 factors needed for complete combustion.
Old Jun 4, 2020 | 08:50 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Was the misfire discovered because the engine was running or idling poorly, or just because of a check engine light?
