Sponsored by: CARiD
Head Light Assembly
Old Sep 4, 2020 | 11:18 AM
wmoor004's Avatar
11 E350 4M
Head Light Assembly
Hello all. I drive a 2011 E3504M (W212) and passenger headlight is damage beyond repair and I need to purchase another one so I have two questions:
1. Replace the assembly with a used one from Ebay
2. Replace both passenger and driver assembly with something else
The dealer said I will need to replace the module also and is charging $3900 but that is out of the question. LOL! Thank you for your assistance in advance.
Old Sep 4, 2020 | 01:18 PM
cetialpha5's Avatar
There really is nothing else. At least not reasonably priced. Looks like you have the headlamp washer so you have the bixenon light so those are more expensive. Make sure you look up the part number you need in EPC to make sure it's a bixenon.
Looks to be about $620 on Rockauto (don't forget the 5% off code on retailmenot.com) but a used one is probably cheaper. They tend to have a V notch on the lense so if you get a used one, ask if it has that. You probably want to pick up a new bulb for the other side as one will be brighter than the other if you get a new one for the other side. How badly is it damaged? They do sell headlamp covers but I guess if the internals are damaged, that won't do you any good.
https://www.rockauto.com/en/moreinfo...447589&jsn=456
Old Sep 4, 2020 | 01:55 PM
konigstiger's Avatar
'71 Pinto
If you do not have EPC access provide VIN I will pull correct part # to comparison shop.
Old Sep 4, 2020 | 05:35 PM
mercerized's Avatar
2020 E450 4matic wagon
TO the rescue !
