Sponsored by: CARiD
2013 w212 e220
Old Sep 5, 2020 | 06:04 AM
Kendog91's Avatar
W212 e220 cdi amg sport
2013 w212 e220
Will 245 45 18 tyres fit? I currently have 20" rims but going down to 18"
Old Sep 5, 2020 | 10:37 PM
S-Prihadi's Avatar
Ur original tires would be 245/40-18" all around. If based on 18". https://www.wheel-size.com/size/mercedes/e-class/2013/
Using 45 aspect ratio at the front may be an issue because the spring base of the front suspension ( McPhearson Strut ) is very close to tire thread.
Old Sep 6, 2020 | 03:17 AM
Kendog91's Avatar
so to tell you the story....I have bought new rims from cm wheels they advised me that the tyres I need are 24 45 18 when in fact it's 245 40 18...after ringing them up and telling them that the tyres won't fit they advised me I could run wheel spacers...would that be possible?
Old Sep 6, 2020 | 06:35 AM
S-Prihadi's Avatar
12.5mm higher is the 45 aspect ratio tire.
https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm
You probably can get away but very-very tight.
Spacers ? NO WAY for this purpose and that much protrusion expected. What kind of tire shop give such an insane idea ?
What is the wheel ET ? It should be ET 48 , if OEM.
Jack up 1 of ur front wheel. Use 2 wheel chokes on the raised wheel as to not allow it to spin or get someone to apply the brake.
Get plastercine https://barbarareid.ca/students-and-...ut-plasticine/
Place 4cm fat plastercine where the point of impact would be. Apply thin plastic on plastercine side which will be squeezed by suspension, so that plastercine wont stick to spring base
Lower tire to road height, brake still applied. Wait a few seconds.
Jack up again and see how much clearance you actually have at the moment from the impression on the plastercine.
I am assuming you are on 245/40-18.
Let us know the result.
Old Sep 6, 2020 | 07:00 AM
Kendog91's Avatar
The et is 45
Old Sep 6, 2020 | 08:53 AM
S-Prihadi's Avatar
LOL ... dumb me
You jack up the car only to get your hand clearance to measure the available gap of tire thread to spring base.
It will stay the same, car jack up or not. LOL.
Becareful yah.
Old Sep 6, 2020 | 10:45 PM
Dingo L's Avatar
E250 CGI
I have been thinking of this very same question for a while.
l actually found a w212 using w213 rims and tyres which is 1 inch bigger in diameter, and as S-Prihadi said it is about 12.5-13mm closer to the car body, that car looks fine......
