Temperature issue
i have eclass 220 2011. Its been very good with him until recently. The issue is that when i am driving in motorway going after 40 min drive in uphill drive temperature goes to 100 and twice reached nearly 120. No temperature red light. But as soon car decelerate and going downhill temperature goes back to 90. In domestic drive for 30-40miles no issue. I have checked with dealer he said bo issue and cleaned the thermostat. But now he is saying since no error the only thing he can do is change the thermostat housing. Collant level is fine. Can anybody advise?
For me it sounds like the OP has an issue with the thermostat not opening enough so it does not allow enough coolant flow for cooling under heavy engine load.
My bet it the thermostat has gone bad.
In my case , a local assembled car, MB Indonesia assembled that is, I got at least the poor water quality issue as I can't verify 50/50 coolant concentration part, but is is a highly suspect too.
The probem is , the damage need years to show itself and in my case 4 years and at 17,000KM . For my case it is the duration not the mileage.
Do pay attention on the water quality workshop uses to mix the 50/50 with coolant concentrate.
https://mbworld.org/forums/e-class-w...i-am-sure.html
Glad to hear you solved the temperature issue
Did you get to see if your thermostat issue is due to mechanical wear and tear or some sort of mineral deposit ?
Your post kinda triggered me to wonder about potential mineral deposit inside my "sealed" thermostat housing, which I can't inspect internally on this 3 liter, it is kinda unique fat shaped plastic version unlike 3.5L version which you can see the actual thermostat.
I don't have temperature issue or any codes, but my car is very low mileage per year, so it will be slow to show..... if indeed my thermostat is not currently mineral free and is not opening a 100% when and if it should. Hmm.
