Swirl flap motor M271 Engine
the star diagnostics came up with two fault codes.
1- Torque calculation error, internal component failure.
2- position sensor for the swirl flap motor has too high frequency.
the car sputters and misfires at low rpms especially with load like ac and lights etc, has rough cold starting. The flap motor has been actuated by the star tool and is having a hard time trying to spin and it seems that it’s faulty checked all the wiring for the sensor and motor they are all okay and physical inspection of the flaps and linkages was also performed and i can tell you for sure the flap motor is faulty.
my questions are:-
A- can a bad swirl flap motor cause the above mentioned symptoms? I’ve read a thread about it and found only one person with similar symptoms on this engine and his issue was also flap motor.
B- can a bad flap motor trigger a torque calculation error fault code?
C- in case of replacement does the new part need teaching process or adaptation?
D- how does a bad flap motor affect vehicles performance?
E- is it a common failure for these engines?
