2010 E550 ABS TC intermittently went out
I have a 2010 E550 with 4matic and sport mode. I was driving it yesterday pretty hard, using the paddle shifters, keeping it pretty close to redline, and the traction control and abs went out. I hit the tc button to no avail. I parked the car, cut it off, let it sit for an hour, and it worked fine the rest of the day. At least no lights came on.
Taken 2 weeks before incident. Ran a complete system check.
Also car has straight pipes which are pretty loud and cause a lot of vibrations where I was running it, needs a slight alignment, and got into a fender bender on the front right last year. I replaced the FR suspension airbag and drive shaft. Needs parktronic sensors 5 and 6. Also did some body work. Any ideas on what it could be? Thanks.
I'm hoping maybe a bad wire on a speed sensor.
Hi and welcome to MBWorld!
Best place for your question is the E-Class (W212) forum for your E550. Moving and good luck!
Bob
Bob
The following 2 users liked this post by speedlimit:
johnjamison (10-05-2020),
pierrejoliat (11-04-2020)
