Noticed caked oil in between pans... 2010 w212 e350
I did my transmission service on my 2010 w212 e350 and noticed some evenly caked oil in between the oil pan and transmission pan. I've included pictures. Any advice would be much appreciated. Centered... From drivers side angle... From passenger side angle... Tried to get a full view as best I could. But can only back my car up so far...
Check the usual spots for oil leaks. The rear centrifuge or oil breather cover, check the bottom. Then there's the 3 oil plugs, one big one and two little ones at the back of the engine. There's an oil cooler up front next to the oil filter housing, the gaskets go bad. Otherwise you will probably have to get it up on a lift to check a bunch of other locations where it could be leaking.
