Locking issue using FOB
I have a rather peculiar situation that just happened this evening. When I parked my car, turned it off, and stepped outside to lock the car using my FOB, the car would not lock. At first, I thought there might have been another door opened (odd, because I was alone), and then I thought perhaps the trunk was opened... but no - everything checked out, but I could not lock the car. I was able to pop the trunk open with the FOB and then lock the car with the lock button found on the trunk panel. Once locked, I was able to unlock the car using the FOB. So that tells me the FOB's battery is fine. I then tried again to lock the car with the FOB, and no luck. It would not lock.
When I got home, I found my spare key and tried the same procedures, and I got the same results: I can't lock the car using the FOB, but I *can* unlock it and pop the trunk. Trying hard to avoid a dealer visit, so I'm really hoping someone knows of this matter and can help.
Thank you all in advance -
Joe
Hold the fob against your lower jaw and operate the lock button. Your jawbone amplifies the signal at the same distance you tried before.
If the doors lock with this technique, then your battery is indeed low.
But... BIG BUT... this happening on BOTH Keys??? what are the odds?
BTW - I put a new battery after my original post and re-tried. Nada....
Do you want to know what I’ve been doing over and over again to lock the car? I was pressing the UNLOCK button – yes … over and over and over again thinking I was cycling between locking and unlocking – using the SAME button!!! I only figured out how stupid I was when I tried it this morning, and I pressed the CORRECT lock button, and then it hit me what I was actually doing last night. IDIOT… Over worked here…
...Plus your bonus Shaved Cat...
Next best would be a ditzy blonde with a shaved cat...
