Trunk refused to close tonight
As the title states, after work I opened my trunk to put some items in and tried to close it manually (by hand)... and it refused to latch. I tried a few more times (a little more firmly) to no avail. I then tried using the auto close button on the trunk lid a few times and that would lower the trunk, but it wouldn't latch and immediately flew open every single time.
Perplexed and angry, I gave up and drove home (not far) with the trunk open. When I got home and parked, I remembered the button on the driver's door to open/close the trunk. This worked. I haven't tried to reopen the trunk yet out of fear that it may not close again.
I've seen similar posts, with different symptoms, all pointing to the soft close motor. With the trunk not even closing manually, is that ruled out then? Or is the latch still electrically controlled by that motor even when manually closing the trunk? Any and all suggestions and help are welcomed, thank you in advance!
I have not had this with my recent E's, but my '03 S500 did this every once in a while, with the trunk open {obviously} hit the trunk open button on the remote which reset the latch mechanism
The soft close you said is working, it's the electric latch that was malfunctioning, it should have reset if you followed the trunk open -hit trunk open on remote, Have you had more issues? I apologize, I'm a distillation and fermentation engineer with 30 years driving 12 different Benz's, Not a Benz mechanic.
The soft close you said is working, it's the electric latch that was malfunctioning, it should have reset if you followed the trunk open -hit trunk open on remote, Have you had more issues? I apologize, I'm a distillation and fermentation engineer with 30 years driving 12 different Benz's, Not a Benz mechanic.No shade being thrown, not dismissing anyone's input. Tone is indistinguishable via text alone. Obviously, you took offense to how I worded my post. I'm sorry you took it the wrong way. I was simply hoping someone might chime in that works on these all day, everyday. Nothing more, nothing less. Everyone's input is welcome, including yours, and I appreciate it!
As stated, I have not reopened the trunk, fearing it may not close again. I live in an apartment complex and I'm not willing to risk that during winter.
I am curious about how the electric latch and soft close motor work together. From what I've read so far, I was under the impression that it's all one assembly. I'd really like to see pictures of how this all is assembled, but I haven't been able to find diagrams, pictures, etc. And during winter, I'm not going to tear it apart to find out the hard way. If anyone has any info about how it all works and/or pictures of what this all looks like, I'm all ears.
Again, I'm sorry if anyone took offense to how I worded my post.
First post.
The soft close you said is working, it's the electric latch that was malfunctioning, it should have reset if you followed the trunk open -hit trunk open on remote,Second post
To me is sounds like either the latch mechanism is either stuck open and/or is being command to open (all the time or randomly). Again, a case where a bi-directional scanner might allow you to actuate the latch and see if its working. Or is the system being command to open when it shouldn't be. Inputs/Outputs/Powers & Grounds as Eric.o would say.
The two mechanisms work together to close/lock the lid, @pierrejoliat you were correct . However I suspect the main "locking" function is performed by the catch mechanism in the trunk lid (M14/7) which looks like this:
I wonder if you could manually trip the rotating catch to the lock position, see if it locks into place, operate the unlock for the trunk and see if the catch releases. Door lock catches can get stuck either from being frozen, dirty or not fully being closed. If they are not fully latched, they won't unlatch (unlock) since some designs rely on spring tension.
My guess is once Meteo's trunk latched and closed, the mechanism reset and it's fine now, I understand his reluctance to try it based on his parking situation. I believe you are correct about the main locking function being in the trunk lid, but the latch in the trunk sill does the soft close function and in my experience is the mechanism that gets "discombobulated"
My keyless go trunk has failed to close only once. I recall my feet dancing below the bumper several times while pirouetting between trunk and grocery cart, before balking to close. I recall pushing the trunk close button without joy, then closed it with the driver's door button. Next time it worked like always, and it's been a couple months without any failures.
So I don't think this is a fatal problem, and encourage OP to challenge it to see if function returns.
I say try the trunk again.
But, how does the car know keys are in the trunk? It is somewhat a line in a water as it is some sort of radio signal to be sensed from where it comes from. How about if the car thinks keys are in the trunk while they are very close outside the trunk? This would explain why the trunk would close fine from the door switch as at that location keys are far away from the trunk in the driver’s pocket.
But it could not be this simple, could it?
There are three parts to the closing and locking system (SEDAN): trunk lid/tailgate central locking motor(M14/7), trunk lid/tailgate locking element (M14/31) and trunk lid control drive unit (M51/3). The central locking motor (M14/7) is the "catch" and "lock" mechanism of the system (in trunk lid). The locking element (M14/31) is the "striker" and part of the "closing assist" (in rear center panel). The control drive unit (M51/3) is part of the "closing assist" (in trunk, under parcel shelf).
The wagon is similar, but different:
- Striker is "fixed" in trunk floor (passive device)
- Central locking motor contains part of closing assist mechanism
- Tailgate locking element is in tailgate and connected to central locking motor
Here's what I observed:
- Trunk Lid Open
- Central locking motor catch is open (ready to engage the striker)
- Striker in lower position (down, towards ground)
- Actuate Lid Closing (inner trunk lid button or driver's door switch)
- Control drive unit begins lowering trunk lid
- Locking element raises striker (upward)
- Central locking motor catches [striker]
- Locking element lowers striker
- Trunk Lid Open
- Manually Closing Lid
- Pull down trunk lid with enough force
- a sticky striker (dirt, lack of lube, too much lube, etc...)
- cable broken (striker is cable driven by locking motor)
- bad locking element motor
- lack of input to locking element motor
