Sponsored by: CARiD
Corrosion
Old Jan 18, 2021 | 06:02 PM
stabystorm's Avatar
Mercedes 450 SL 1979
Corrosion
Live in Norway. Car 9 years. MY 2012, unexpected corrosion in rear subframe and a lot of corrosion spots at aft part. Needed to remove the rear axle, sandblasting the structure and repaint including corrosion inibitor. If you live at a location where the enviroment is hard for you car will I recomend to treat it for corrosion and remove the plastics underneath the car once a year for thruly washing.
Rear axle removed. Subframe will be replaced
Easy access
In front of LH wheel collected mud during the years. Not visibl when the inner parts of the fender was installed
before sandblasting
after sandblasting
used part waiting to be installed. Bought at mercedes own second hand shop in Europe. mbgtc.de
Rear subframe forward lower attachment. Severre corrosion close to the drain hole
Before I had the sandblasting gun get over the area. Looks good at first glitch. When i hit it with sanblasting gun the paint just fall of. (Before)
The result after sandblasting. the darker spots was initial corrosion (After)
Old Feb 5, 2021 | 02:19 PM
stabystorm's Avatar
Painted x2. Epoxy primer and 2k top paint
Have until know with restoration of rear axle used about 100 man hours, Subframe, all suspension arms and attaching parts as bolts / nuts replace total spare parts cost about 2500 USD
Old Feb 6, 2021 | 02:25 AM
BenzV12's Avatar
W212 FL
Great job,
I feel like watching Wheeler Dealers
Old Feb 6, 2021 | 03:19 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Near the beach car?
Old Feb 7, 2021 | 04:06 PM
stabystorm's Avatar
50 man hours later 150 in total. Finished work on the car. The car is running in Oslo, The capital town in Norway but mainly not close to the sea. I belive the road salt have been to hard for the original corrosion protection to handle. The seals between the diffrent plates was very good performed by Mercedes. Nevertheless it took me some time to correct the underside of the car. The sandblasting and painting was most time consuming.
In addition, replaced the compressor. The old one was found leaking.
Rear axle re installed
Corrosion protected underfloor. Before exhaust plates
Bolts / and sway bar links for 400 USD, was replaced
Subframe installed in rear axle and new suspension arms including bolts. The suspension arms was tightned in normal "drive" position. The subframe got a additional layer of 2k paint and thereafter corrosion protection with Mercasol
Old Feb 8, 2021 | 11:44 AM
machinemanjr's Avatar
Very nicely done. Thank you for sharing your pictures with us!
