Sponsored by: CARiD
2011 E350 power window issue
Old Jan 19, 2021 | 09:35 AM
DonLawson84's Avatar
2011 E350 Wagon
In my 2011 E350 Wagon I noticed if you put either passenger or driver front windows down partially (30% or less) they will not go back up unless I put them down past 30% open. I read a thread that showed how to reset to close position, but still no luck.
Old Jan 19, 2021 | 09:51 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
So when the windows are lowered ~30%, when you press the switch to raise them what happens? I know you said they don't go up, but do you hear any noise? Does it sound like the motor is trying to raise them, or do you hear any "relay" type click? Or does is simply sounds like nothing is happening, as if you didn't even touch the switch?
Also are you pulling the window switch up a little or past the "click" and releasing as the former is "manual" and the latter is "auto". For the auto function to work the window needs to be normalized.
My first guess would be normalizing the windows... what procedure did you follow?
Old Jan 19, 2021 | 10:15 AM
2011 E350 Wagon
I would have to check again to listen for relay engagement, but when I press window up, they go up about an eighth inch and then go back down. If I lower the window 100%, then travel to anywhere below 30% and stop, I can still close them both. It is only if I stop them in that range from 0% open / close to 30% open while opening. The window acts normal if I go from close - full open - close or .... from close - anything more than 30% - close
Old Jan 20, 2021 | 07:09 AM
2011 E350 Wagon
I do not notice the sound of any relay engagement, but the issue is intermittent. Yesterday on the ride home was fine for the first 20 minutes, then it started again. When I attempt to put the window up, it moves up about an 1/8 inch then sends itself down. Do I need lubricate the inner / outer window seals? if so, what is a recommended?
Old Jan 20, 2021 | 08:21 AM
RA72825's Avatar
Maybe disconnect the main battery for several minutes, reconnect and then do the window/ sunroof reset. Open and close and hold the button for 2-3 seconds. I’ve always used silicone spray directly in window felts for slow moving glass. It is non invasive and cleans up easily.
