Sponsored by: CARiD
red battery light ???
Old Jan 20, 2021 | 07:15 AM
alex-w212H's Avatar
e 300 hibrid
Hello. I also have a problem with my car, E300 hybrid (w212-2).
the red battery light came on, plus the message see owners manual.
the car being a hybrid, I don't know if I have to go to the dealership to solve the situation or to call a service with battery books at home with assembly.
for hybrids is there any special procedure with "high voltage" ??
I do not know what to do
Old Jan 20, 2021 | 07:23 AM
alex-w212H's Avatar
e 300 hibrid
pics
Old Jan 20, 2021 | 09:09 AM
konigstiger's Avatar
'71 Pinto
May simply be weak main or starter battery, although not your exact malfunction attached bulletin notes: “For diagnostic work the 12V on-board electrical system must be charged or boosted using an appropriate charger!” I suggest having dealer check it.
File Type: pdf
Old Jan 20, 2021 | 09:26 AM
alex-w212H's Avatar
e 300 hibrid
the car works, it starts well, it works ok, only that in a few seconds that indicator light appears.
I definitely have to do this, to **** at Mercedes but I'm full, in 7 days I can barely receive myself. it is what it is
Old Jan 20, 2021 | 12:33 PM
RA72825's Avatar
Your battery at 11.5v is dead. Should be 12.6+
https://mbworld.org/forums/e-class-w...lternator.html
Old Jan 20, 2021 | 12:39 PM
alex-w212H's Avatar
e 300 hibrid
Thanks a lot for the reply, I sincerely appreciate.
now the question is. it is enough to take a VARTA aftermarket battery, similar in technical data to the OEM one, which is also based on varta.
I wonder if this type of car, hybrid, involves some computer reset to read the new battery as "new". Besides the financial costs, the problem is that at Mercedes the schedule would be somewhere in 10 days. and I can't really stay without a car.
and the version with a battery bought on the internet is instant, it comes home and installs it.
or is it possible only an effective change of "battery" and nothing more ??
Old Jan 20, 2021 | 12:48 PM
RA72825's Avatar
Most owners here have installed new batteries without any special coding by the dealer to recognize that the battery has been replaced. I know BMW and other car manufacturers require this and perhaps your Hybrid might also, but I doubt it. You can call the nearest dealer and ask if the battery needs to be coded. Hopefully, you will get a straight answer. You do not need to buy a Varta OEM battery as a replacement. Any AGM battery that meets the original specs (battery size, group, cold crank amperage) should work. There are many battery threads in this forum if you search. Good luck!
Old Jan 20, 2021 | 12:58 PM
alex-w212H's Avatar
e 300 hibrid
Thank you very much. I'll look and read more about it.
but I'm almost convinced of what you wrote me and thank you very much.
come back with the solution )
sorry for the childish questions but that's how we learn.
Thank you very much
Old Jan 20, 2021 | 01:07 PM
'71 Pinto
OK if, in fact, it is only the battery it is DIY including hybrid see attachment.
File Type: pdf
Old Jan 20, 2021 | 01:14 PM
RA72825's Avatar
Konigstiger has posted the exact procedure for replacing your specific trunk battery and I don't see any reference that it must be coded to the car. You should be all good.
Old Jan 20, 2021 | 01:17 PM
alex-w212H's Avatar
e 300 hibrid
wow. super information. thank you very much Konigstiger and KEY08. I will sleep much more peacefully and I will definitely solve this situation with the battery much faster.
thanks
Old Jan 22, 2021 | 01:59 PM
alex-w212H's Avatar
e 300 hibrid
problem solved. I bought varta afermarket non OE, mounted at a service. and go for alternator charge check for battery warranty. everything was OK. Thanks a lot for the advice
done
Old Jan 22, 2021 | 02:05 PM
RA72825's Avatar
Nice conclusion to your issue and thank you for returning to let us all know. It is much appreciated.
