Sponsored by: CARiD
Aircondition not working properly
Old Jan 24, 2021 | 04:16 PM
danijoh95's Avatar
E220, 2015
Hello. I have a issue with my A/C / fans.
The A/C stopped working, which I thought was a faulty blower-motor and/or resistor. I replaced both, and now it turns on, but only works 20 seconds before it shuts off. Then it takes a 5 second break before it works 20 seconds again, and keep going like this for approximately 15-20minutes before it dies completely until I stop and start the ignition again.
I've checked that the parts are the correct ones, and that they're plugged in correctly so none of the plugs or connectors are loose.
Somebody with the same problems, or help to what I can do / check?
I read something about an hidden A/C menu and thought maybe it needs to be reset because of new parts, but I can't figure out to access that menu.
Cheers
Daniel
