Sponsored by: CARiD
Driver’s side puddle light not working?
Old Jan 27, 2021 | 12:21 AM
alan_e550's Avatar
2011 Mercedes-Benz E550 4Matic
Hi everyone, I was changing the nasty yellow puddle lights on my 2011 e550 to led ones and my drivers side light no longer works. These lights are advertised to be plug n play and the one on the left side was working just fine. I had my indi test it and he said that the light itself was fine however the positive end on the mirror itself was only pulling 1.1 volts. Is there diy fix for this? Thanks for any help!
Old Jan 27, 2021 | 10:12 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
1.1 volts, across the connection for the bulb? Could be a bad ground, recheck the positive against a known good ground and see if the reading changes. I assume were expecting 12 VDC, so next will be tracking down the positive wire and checking it at its source if its still 1.1 VDC...
