Sponsored by: CARiD
How to remove maintenance warning 2011 e550
Old Jan 30, 2021 | 02:36 PM
alan_e550's Avatar
2011 Mercedes-Benz E550 4Matic
Hi everyone,
I keep getting a warning when I turn my car on saying the A1 service is due in X amount of days. I maintain the car myself and will not be selling a kidney to get my oil changed at the dealer. Is there a way to turn this off? Thanks!
Old Jan 30, 2021 | 02:54 PM
konigstiger's Avatar
'71 Pinto
Try this.
File Type: pdf
Old Feb 1, 2021 | 12:09 PM
alan_e550's Avatar
Try this.
I tried that however nothing happens when trying step 5. Is there anything else I can do?
Old Feb 1, 2021 | 12:29 PM
nota_amg's Avatar
2013 SL550 BiTurbo
This is all from memory, but i've included a video link that shows how it is done as well
1. Remove the "push-button" start button if equipped.
2. Turn on ignition with key and make sure your cluster display is on the "mileage" screen that shows total mileage and the trip odometer.
3. When display is at odometer, turn off ignition, remove key and open the drivers door.
4. Close door and insert Key into EIS
5. Turn key to the 1st position and then press and hold the "Call-answer" button on the right side of the steering wheel and then the "OK/Enter" button on the left side("Call-answer" 1st, then "ok" button, must be quick, and in order, not at the same time) for approx 5 seconds and the (Dyno/Maint" menu will pop up in the cluster.
6. Press the "ok" button and then use the arrows to find the Maintenance menu and then choose "Confirm Service" or something to that effect. Cycling the key(off/out/in/on) should clear the menu.
Old Feb 1, 2021 | 12:56 PM
alan_e550's Avatar
https://www.youtube.com/watch?v=oFwXR19Uzno
Solved! Thanks nota, really appreciate it
Old Feb 1, 2021 | 06:35 PM
nota_amg's Avatar
2013 SL550 BiTurbo
no problem
I use it a lot!
