Sponsored by: CARiD
Rear Diff replacement
Old Feb 1, 2021 | 07:17 PM
MGreyB's Avatar
2010 E350
Need help! How difficult is it to replace rear diff on 2010 E350 4Matic? Can't find any videos on youtube, but it looks as if it's not too bad of a job.
It looks like with the removal of the two top links and the bottom link from the carrier, then tilt the carrier down, the axles should have enough clearance to slide out of the diff.
Anyone done this before?
Old Feb 2, 2021 | 12:31 PM
S-Prihadi's Avatar
Nope.
mine is RWD, but it should be 100% the same scenario for rear diff of a 4 matic.
Old Feb 2, 2021 | 07:34 PM
nota_amg's Avatar
2013 SL550 BiTurbo
yeah, pretty sure you don't have enough room to remove them from the diff with the rear suspension in place
Old Feb 2, 2021 | 08:08 PM
tjadams3721's Avatar
S550 E500 E350
I take one side of the rear suspension apart enough to remove that axle. Usually all of the arms off the knuckle except for the spring arm. That’ll give you enough room to get the axle out of the hub then knock it out of the rear diff.
Once one side is out you can loosen the other from the diff and lower the diff and tilt on the way down.
Old Feb 2, 2021 | 10:15 PM
S-Prihadi's Avatar
I use a workshop service , DIFF removed because I installed Quaife ABT LSD in lieu of open DIFF
If you want to DIY this job, unless you have proper supporting equipments and extra person to help, I suggest use voice command method instead.
Voice Command : Hello workshop, I need to do XYZ for my car
Old Feb 2, 2021 | 10:20 PM
S-Prihadi's Avatar
And when all done with the DIFF.... make sure you do a proper pre-tension at car normal ride height ( tires on ground ), for all the arm's bushings which were loosened during this job.
Old Feb 4, 2021 | 12:20 PM
MBNUT1's Avatar
2010 E350 4Matic
Why do you need to replace it?
Old Feb 5, 2021 | 02:20 PM
MGreyB's Avatar
2010 E350
It is humming rather loudly. Drained fluid and it looks like pearlescent paint...
Old Feb 5, 2021 | 02:30 PM
MGreyB's Avatar
2010 E350
Thank you very much! Very helpful info!
Old Feb 5, 2021 | 05:21 PM
MBNUT1's Avatar
2010 E350 4Matic
How many miles are on it?
Old Feb 8, 2021 | 03:26 AM
Mohd Saadi's Avatar
W212 2011
​​​​​​Mine is humming too ☹️
I've replaced the diff fluid and nothing changed ☹️
