Sponsored by: CARiD
Stuck in park
Old Feb 11, 2021 | 12:32 PM
Andy-Coventry's Avatar
2013 E300 Estate (Hybrid)
Stuck in park
I have 2013 E300 Estate which will not shift into D or R from P. Engine runs and revs. No warning lights up. Looking for a likely diagnosis.
Old Feb 11, 2021 | 01:23 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Somebody's gonna ask so it may as well be me...
What codes have been thrown? You may need something better than a generic OBD2 scanner to retrieve them.
Old Feb 11, 2021 | 01:33 PM
RA72825's Avatar
If you are using Keyless Go, pull the button and insert the key. turn to position 2 without stepping on the brake and see if the selector will move into neutral.
If so, turn the key back to 0 and then step on the brake to start the car and see whether it will shift.
Old Feb 11, 2021 | 02:07 PM
RA72825's Avatar
Also, there are other similar threads to review:
Could be bad ISM (intelligent servo module).
https://mbworld.org/forums/e-class-w...tuck-park.html
