Sponsored by: CARiD
Clima panel problem
Old Feb 19, 2021 | 11:28 AM
alex-w212H's Avatar
e 300 hibrid
Clima panel problem
hello again. I have a problem that persists with the climate panel. The car is hybrid, E300 hybrid. I changed both batteries and what to start and accessories, to exclude the problem of voltage ?! the problem is that the climate panel goes out and lights up on the go. it actually blinks and at some point it stays on. this came out of the blue. not necessarily in cold weather. the idea is that he doesn't do it all the time. no error occurs on the STAR tester. Can you give me some advice ... where can I start the investigatios? thanks a lot
Old Feb 19, 2021 | 11:41 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
STAR tester, is the software Xentry? Any other symptoms?
Post up your VIN and we can provide a wiring diagram for the unit if you decide to check for powers, grounds and signals. Have you removed the Clima unit? Maybe it just a loose connector from prior work...
Old Feb 20, 2021 | 01:39 AM
alex-w212H's Avatar
e 300 hibrid
Hello. exactly with Xentry software. no I didn't remove the climate panel. I will try. I hope it's an easy fix. it has no other symptoms or errors. VIN is WDD2120981A819994. yes, I think that the scheme helps a lot to know where to start investigating. or at least I see what "weaknesses it would have"
Old Feb 20, 2021 | 08:37 AM
konigstiger's Avatar
'71 Pinto
Batteries already replaced, check refrigerant circuit for leaks and consider software update per attached bulletin before moving on.
File Type: pdf
File Type: pdf
Old Feb 21, 2021 | 09:15 AM
If the guidance in the bulletin doesn't resolve your issue, here's the wiring diagrams for further troubleshooting.
Old Feb 21, 2021 | 09:24 AM
alex-w212H's Avatar
e 300 hibrid
Super. thanks a lot. I will go on Tuesday (then I have programming) to try to solve, thank you very much for all the advice, I'll keep you posted on everything I do. thanks
