2014 E550 Brake Job
I’ve been reading the forum but still can’t decide a lot of people are saying Zimmerman rotors are good, some say Brembo, some say Centric.
I also want good pads since the cars tuned and has a lot more power. Would prefer no brake dust but if they’re better brakes with the brake dust I wouldn’t mind.
Which ones would you guys recommend to go with?
Your better off replacing the front pads, if your looking for more aggressive braking and that will come with more dust and not less. EBC, Hawk, Pagid have good offerings for higher performance pads. However there's a fine line, because some pads will require more heat input to get that higher braking potential.
If you can lock-up your brakes, then another consideration is a tire with more grip as that's usually the limiting factor on the street. If were talking about track days or auto-x, where your doing heavy braking repetitively, then factory-style pads will fade and that's a different story.
