Sponsored by: CARiD
servicing panoramic roof
Old Mar 23, 2021 | 01:16 PM
alan_e550's Avatar
2011 Mercedes-Benz E550 4Matic
Hi everyone,
I decided I want to service the panoramic roof on my '11 e550. It doesn't creak or make unusual sounds and works perfectly but some of the plastics look a little discolored and it could probably use some lubrication. are there any instructions as to what I should do? Thanks for any help!
Old Mar 23, 2021 | 01:35 PM
konigstiger's Avatar
'71 Pinto
Certainly, see attachment. You can use Plastilube as a cost effective alternative to MB products.
Old Mar 23, 2021 | 02:08 PM
alan_e550's Avatar
I see there are 2 different kinds of lubricants, would plastilube be just as effective?
Old Mar 23, 2021 | 02:11 PM
'71 Pinto
IMHO yes, your call. BTW, do not use WD40.
Old Mar 23, 2021 | 02:19 PM
alan_e550's Avatar
Is this the correct plastilube to use?
Amazon Amazon
Old Mar 23, 2021 | 02:21 PM
'71 Pinto
Yes.
Old Mar 23, 2021 | 02:38 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
The factory stuff is a Krytox formulation best I can tell... ECS Tuning sells the grease in small jars for a fraction of the tub. The other is a liquid version of some Krytox formulation for the rubber seals, commonly used for the pano and soft tops.
Krytox is pretty awesome grease, but $$$.
Old Mar 23, 2021 | 02:44 PM
alan_e550's Avatar
Do you have a link for those products on ecs?
Old Mar 24, 2021 | 04:03 AM
cetialpha5's Avatar
Free shipping if over $49 otherwise if you don't have enough to buy, you can get it on eBay for a few dollars more. I believe the half ounce you get is about 14 grams but the MB container is 500 grams so you get 35 times more for 7x the price. The 1/2 ounce will last a while though, used it a few times and still have plenty left.
https://www.ecstuning.com/b-genuine-.../0019894651~a/
https://www.ebay.com/itm/Gleitpaste-...s/184721375761
https://parts.mercedesbenzofwappinge...ste-0019894651
Old Mar 24, 2021 | 01:00 PM
alan_e550's Avatar
I plugged in the part numbers from the service manual konigstiger posted and the "special sliding compound" directed me to this: https://www.ecstuning.com/b-genuine-...nt/0009893660/
I'm a little confused as it says it's a convertible top sealer, am I better off just buying this and the sunroof lubricant?
Old Aug 11, 2022 | 02:56 AM
Mercedes82000's Avatar
gla
Hello,
A problem????
