Sponsored by: CARiD
signalling problem in cold weather
Old Mar 24, 2021 | 09:17 PM
medhath's Avatar
2012 E350
The signals are mixed at cold temperatures on my 2012 E300, I try to signal right, the left signals will blink at cold temperatures (-15C and below). Car back to normal after driving for 15 minutes.
Old Mar 24, 2021 | 10:05 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
That's a really odd issue... my first thoughts are at low temps, battery health is compromised. This can lead to weird electrical phenomena on these cars. I don't even know... I'd start by pulling codes with an appropriate scanner capable of deciphering MB code and not just a generic OBD scanner.
I'd love to see live scanner data off the steering column module looking at the switch inputs when your signaling right, but the left turn signal engages...
Old Mar 24, 2021 | 10:41 PM
medhath's Avatar
2012 E350
This problem started last year, the car is now 9yrs old running on original battery. Do you think battery will solve this problem?
Old Mar 24, 2021 | 11:12 PM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
A new battery might be in order. You might try putting a charger on the battery and see if the problem remains the same at about the same temperature. A lot of electrical devices don't work the same under low voltage conditions.
