Yellowish brake fluid turned blue?!
Dec 2020 to now is only 5 months max.
You just got this car last Dec ?
Honestly I do not know how much does an ABS module retains its old fluid due to its design albeit proper flush been done, but I believe it retain a little bit at least.
They need to do double flush to get rid of old blue brake fluid completely and that will take approx 1.8 liters.
What I mean of double flush is as follows, assuming your car is LEFT HAND DRIVE :
In the sequence as below ...... longest pipe line to shortest
Rear, right side brake, flush out 200cc >>> Rear, left side flush out 200cc >>> Front right/passenger flush out 200cc>>> Front left/driver flush out 200cc.
Do again one more round for above.
NOTE : If not based on cc ( volume), one can do based on seeing clear new brake fluid gushing out of all the bleeder valves.
If you want to claim to MB service center, I can't comment on that but I suppose it is a good try because it is worth a try.
Drive safe
Just emailed to MB for the possible cause. Will update when having their reply.
https://www.motiveproducts.com/produ...dc713487&_ss=r
Watch how to use this kit and how to bleed, very easy, I promise you.
Find something to protect your paint near the brake fluid reservoir, cause brake fluid can eat thru paintwork.
No need to test how "wet" your brake fluid is with that pen thingy.
Google more about brake bleeding to get yourself comfortable.
Enjoy..........
way I will remember it has been changed. It is also easier to tell when the lines are changed to the fresh fluid by the color change during bleeding.
I do this my other vehicles as well. This is a pretty normal pro tech procedure, especially among racers.
Now that the DOT has ruled that brake fluid cannot be blue (so it won't be confused with blue coolant), Super Blue is history. Super blue was called Super due to its very high boiling point for racing.
