Airmatic Diagnostics
Peter
Parts used...
4mm tube -
Peter
Parts used...
4mm tube - Amazon.com: Utah Pneumatic 4mm Od Or 5/32"10 Meters 32.8 Feet PU Air Tubing Pipe Hose pu Air Hose for Air Line Tubing Or Fluid Transfer Pneumatic tubing (pu Tube 5/32): Home Improvement
Male connector - Amazon.com: AIRSUSFAT Air Suspension Spring Strut Valve Air Suspension Valve for Audi Q7 VW Touareg Cayenne 955 Jeep Air Compressor Fittings M10 for Mercedes W164 W251 W166 W212 W221 W220 W211 7L0616813: Automotive
Valve - Amazon.com: Beduan Push to Connect Fitting Ball Valve, 4mm Tube OD Pneumatic Air Flow Control Ball Valve Straight Union Connect Adapter: Home Improvement
Female to female coupling - Lube Line Female Thread Coupling M8x1 106201 - Lube USA - Shop Now (cnc-specialty-store.com
