Coolant color
Much more work though, I agree it'll get you a more complete exchange, but just using the petcock and changing every 50k takes about 10 min to get to and 30 min to do completely without the hose kerfuffle.
Received 1,008 Likes
'11 E350, '11 E550, '98 M3, '95 E320
I wouldn't disconnect the hoses either... but I agree if your doing a spill and fill, then just draining the radiator via the petcock is super simple. On our car, I wanted to drain as much as possible since I was replacing the thermostat and oil cooler. The coolant was unknown, not G-48 as it had a dark amber color (maybe G-05 mixed with G-48, PO was in there). Ended up draining the radiator, block and still flushed a good 10+ gallons thru the system (multiple spill/fills).
pierrejoliat (07-26-2021)
