Sponsored by: CARiD
DAG104
Old May 24, 2021 | 07:30 PM
DAG104's Avatar
2010 E550
DAG104
2010 E 550 Have three code PO 524 PO859 PO 954 Trying to find what sets the off and what the fix would bf still waiting for my munal to get up and running
Old May 24, 2021 | 09:11 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
thats p0 not PO (zero, not oh)... google suggests....
Mercedes-Benz P0524 Engine Oil Pressure Sensor/Switch Circuit
Description Engine Oil Pressure Too Low
What does this mean?
The PCM continuously monitors the engine oil pressure. The Oil Pressure Sensor/Switch sends a signal to the PCM when the engine is running.
Possible symptoms of OBD code P0524 Mercedes
– Engine Light ON (or Service Engine Soon Warning Light) – Oil pressure warning light ON.
Possible causes of OBD code P0524 Mercedes
– Low oil level or motor mechanical fault – Open or short oil level sensor circuit condition – Poor oil level sensor electrical connection – Faulty oil pressure sensor The Error code is generally activated on detection of the following conditions: The P0524 Mercedes is detected when the circuit from oil pressure sensor to PCM is malfunction.
Possible Solutions
The most likely cause is a faulty oil pressure sensor/switch
P0859 Traction Control Input Signal High
Mercedes-Benz P0954 Auto Shift Manual Control Circuit Intermittent
Old May 25, 2021 | 11:46 AM
DAG104's Avatar
2010 E550
Dag104
Thanks for the replay
