Sponsored by: CARiD
angle sensor ..
Old Jun 14, 2021 | 05:08 AM
mokrex's Avatar
w212
angle sensor ..
Witam wszystkich..
Posiadam Mercedesa W212 z 2013 roku, po drugich windach. Na liczniku mam błąd ESP, po podłączeniu interfejsu okazało się, że jest problem z czujnikiem kąta skrętu, a dokładnie moduł kierownicy z łopatkami nie widzi czujnika skrętu. Moje pytanie brzmi gdzie znajduje się ten czujnik??? Wiem że przed podnośnikiem jest w module gdzie są manetki..w tym modelu wydaje mi się że to osobny czujnik...proszę o pomoc. Dziękuję i pozdrawiam. Blad: C2205
Old Jun 14, 2021 | 08:16 AM
Sunnyslope48's Avatar
2016 E350 Sport 2WD
Old Jun 14, 2021 | 01:07 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
The angle sensor is part of the steering control module, which also contains the turn signal, cruise/distronic and shifter stalks. The actual sensor for steering angle is within the assembly, the outer portion is stationary and the inner part rotates with the steering shaft.
Unfortunately is all one assembly... I'm sure it can be disassembled to an extent. I'm guessing your trying to possibly repair to avoid replacing the module, which I presume is close to a grand.
Old Jun 14, 2021 | 01:22 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Czesc.
That's a hard one. Steering sensor usually is mounted in steering column, but EPC is not finding it for this car, while looks like you are the 1st one with this problem, so no forum topicks.
I could find upper components assemble https://www.mbdirectparts.com/v-2014...per-components
what hopefully will have the switch build in, but can't confirm it.
So the best start would be take a look inside the column and look for disconnected plug, or broke wire.
Powodzenia.
