Need a shop to install rear adjustable camber arms in Dallas
drop the lower arm on one side
pull spring out
remove the inner and outer bolts on the factory camber arm.
the only time consuming bit is getting the lower arm back in position as the spring fights you but still isnt bad.
pull spring out
TX, no rust… 4-8 bolts + alignment. I’d shop around.
Same shop also has a high labor cost but it has a strong reputation for a reason.
European Auto Haus by SMU may also be a good price check, have had Rover serviced there several times.
