HELP! 2014 e3504w Rough idle???(Dashboard pointer jitter between -/+50 rpm)
But when I turn on the air conditioner or after my ECO start/stop is activated (the engine is re-ignited), my dashboard pointer will start to twitch in the range of +/-50 rpm.
I hope you can understand. I have tried very hard to express it, but English is not my first language.
Thanks!!!!
When idling at 550rpm, there will be twitching of the rpm pointer on the dashboard, just like the jump of an electrocardiogram, but it is irregular, and the range of twitching is about 575-525 rpm.
At normal temperature, I did not feel an abnormality from the engine speed. It is only displayed on the dashboard.
Some details of cold car start at idling: the engine will be below 1500rpm and above 1000rpm during ignition, and will drop below 1000rpm within 1-2 seconds. During this process, the engine is very noisy. After that, the noise of the engine is significantly reduced (it feels back to normal), the engine will stay at 800rpm for a period of time, and the speed may gradually rise a little but not exceed 900rpm. Finally, the rpm slowly drops to 550 rpm at a constant speed (the idling speed is also 550 rpm when the temperature is normal). The engine is very smooth and quiet at this time and there is no body shake. The whole process takes about 10-20s in total.
No OBD2 code is displayed, and all electrical appliances are working properly.
If my description is too complicated, I can try how to upload a video here.
No fault code is displayed, and all electrical appliances are working properly.
