Those with EPC 2015 or newer, please assist
Received 4,553 Likes
Hi Guys,
I am curious about a plastic coolant pipe at the REAR end of the V6 3.5L M276 engine which is so close to the firewall and replacing it can be a $$ nightmare.
I use my 2018 EPC and never could find the plastic pipe I seen my E400 M276 3.0 TT has ( under ENGINE COOLING) , which M276 3.5L NA also uses.??? Hence I am worried my EPC 2018 version from Ebay maybe corrupted
This is a 3.5L M276
Item 1 is the plastic coolant pipe I speak of. For M276 3.5L NA in EPC, I can't find it in ENGINE COOLING SYSTEM. Item 2 is available under HVAC for 3.5L NA
M276 3.5L NA
In EPC for M276 3.5L NA under HVAC only item 2 is shown, but there is no trace of Item 1 in entire EPC if engine is M276 3.5L NA ...weird, above and below photos showed that 3.5L NA version also uses Item 1.
Item 2
Item 1 if stand alone
Item 1 on 3.0L TT, it is shown in EPC
The said plastic pipe Item 1 on M276 3.0L TT
Thanks..........
This is a 3.5L M276
M276 3.5L NA
Item 2
Thanks..........
S-Prihadi (09-22-2021)
Dang..... THANK YOU .... BMW
Wow, different engine, different heading where this plastic water pipe hides under
I never thought water handling component can fall under gas handling component....oh EPC.... hhhmm... always have to learn something new.
I should have used part search instead hehehehe.
Thanks again ...
Thanks again ...
Received 1,503 Likes
Thanks again ...
Thanks again ...
I dont use ISPPI, I use ebay clone EPC...
Information purpose : ...DAMN, there is indeed a M276 3.5L Turbo version.
I thought it was a wrong information at Wiki and some motor magazine
Has anyone with M276 ever replaced the item 1 pipe ?
