Sponsored by: CARiD
Which transmission is in E350 2013 pre facelift model, 7G-tronic or 7G-tronic Plus?
Old Sep 22, 2021 | 07:59 AM
R3inhardt's Avatar
MERCEDES W212 E350 2013
2013 E350 vin: WDDHF5KB5CA623857 ,No start/stop feature so just 7G-tronic correct ?
Old Sep 22, 2021 | 09:48 AM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
The switch to 7G+ was in 2011…. there’s documentation, if you search, that shows the cut-off date and differences in oil pan design.
Old Sep 22, 2021 | 10:27 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Run data card and it should tell you.
Other indication is that 7G require single service at about 40k miles and then "for life"
when 7G+ require service, depending on the engine every 60-70 k miles.
7G+ also has finer filter.
Old Sep 22, 2021 | 11:28 AM
konigstiger's Avatar
'71 Pinto
Plus
File Type: pdf
Old Sep 22, 2021 | 12:53 PM
R3inhardt's Avatar
Thanks for your replies I thought only MB vehicles with start/stop and eco features had PLUS , one more question . Does sport package transmission differ from others , some online vin decoder sites say 427 AMG SPEEDSHIFT MCT 7-Speed Sport Transmission for my vin , this is impossible right ?
Old Sep 22, 2021 | 02:02 PM
'71 Pinto
Here’s your data card. Most likely an error MCT transmission is essentially the 7G-Tronic automatic transmission without a torque converter of which you have. I have also seen 427 = 7G-TRONIC PLUS.
File Type: pdf
Old Sep 22, 2021 | 02:54 PM
R3inhardt's Avatar
very informative , thanks again
