Sponsored by: CARiD
Where is MAP sensor on 2012 E550 M278
Old Dec 6, 2021 | 03:20 PM
no_mulligan's Avatar
'12 E550, '10 ML350, '06 E350, '20 GLC300, '21 GLC300
I can't seem to locate where the Map sensor is located. My VIN in WDDHF9BB4CA491570.
Where is this located along firewall? Driver's side? Passenger side? High? Low? Any disassembly required for access?
Old Dec 6, 2021 | 04:56 PM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Isn't it on the backside of the V8 air box.
Old Dec 6, 2021 | 05:42 PM
konigstiger's Avatar
'71 Pinto
Pressure sensor downstream of throttle valve.
Old Dec 7, 2021 | 06:39 AM
Siegmann's Avatar
10-second E550
Curious- what symptoms was your car showing?
Old Dec 7, 2021 | 07:02 AM
A bit of roughness at startup/idle. Random misfire mostly in cyl 1and some in cyl 3. CEL P300. No signs of oil in cam shaft position sensor or cam magnets electrical connections. I changed those out months ago plus added pigtails to the cam magnets.
Old Dec 7, 2021 | 07:03 AM
Thank you Konigstiger.
