Sponsored by: CARiD
How to remove radiator petcock on 2010 E250 CGI
Old Jan 18, 2022 | 06:37 PM
Milor's Avatar
Mercedes Benz E250 CGI
Hi all,
I'm losing coolant via radiator petcock, so I'll have to replace it.
Any idea how to remove radiator petcock on 2010 E250 CGI, please? I want to make sure I don't damage something. Photo attached.
Milo
Old Jan 19, 2022 | 09:10 AM
Arrie's Avatar
Originally Posted by Milor
Hi all,
Milo
Turn 90 degrees CCW, pull out until stops (about 5-6 mm) then turn another 90 degrees CCW and then pull it out all the way.
This is how it works my 2010 E550. Part looks the same.
Old Jan 27, 2022 | 05:52 PM
Milor's Avatar
Many thanks, Arrie. Will try. Just before I do that, I would like to pressure test the system. What is the maximum pressure I can apply for testing? I expected the radiator cap (overflow tank cap in this case) to indicate the pressure rating, but no such thing. The web mentions 1.4bar (20PSI) and 2.1bar (30PSI) for this cap. Confusing. Would anybody have a correct pressure figure, please?
