Sponsored by: CARiD
S212 seat cover replacement
Old Feb 4, 2022 | 06:36 PM
mercerized's Avatar
2020 E450 4matic wagon
Recently discovered the dreaded MB-tex rip while I was inspecting the front covers on the cylinder head - found a leak on the LH bank, too. Good way to start the weekend, eh?
Plenty of good comments from members here regarding the seat covers:
https://mbworld.org/forums/e-class-w...at-ripped.html
Big thanks to konigstiger for posting the WIS: https://mbworld.org/forums/e-class-w...ml#post6973169
It appears that the seat frame can remain installed whilst completing this jobber.
In other words, just take off the storage box and lift out the seat cushion and disconnect harnesses.
Looked kind of straight forward. Are there any tricks to look out for? Thanks
RGDS, roger
Old Feb 4, 2022 | 09:18 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
For me, unplugging the seat heater from the floor mounted control unit was the most difficult part, the seat bottom itself if I remember is six bolts, two on the storage box and four under the frame for the "U" brackets at the front, then slide forward out from under the backrest, but not too far, being careful of the heater wire.
Old Feb 5, 2022 | 01:44 PM
mercerized's Avatar
Thanks.
I assume you mean that the disconnecting and loosening has to happen before sliding the lower seat? Which means working underneath the seat ?
Old Feb 5, 2022 | 02:23 PM
Originally Posted by mercerized
Thanks.
No, just not a lot of slack in the wires, so slide it forward enough to get it out from under the back, but only like 4-5". Getting the little blue connector out was the hard part for me, also I forgot about removing the rear footwell light first
Old Feb 7, 2022 | 10:45 AM
atraudes's Avatar
2011 E350 Wagon, 2010 GL450
Yeah that connector is a pain to get disconnected. Make sure you use an OEM seat cover. I tried aftermarket and was not at all impressed.
Old Feb 7, 2022 | 12:29 PM
mercerized's Avatar
Thanks.
