Sponsored by: CARiD
e550 m278 engine error code
Old Feb 10, 2022 | 01:07 AM
dexter_morgan's Avatar
2012 E550 4Matic
I recently purchased 2012 E550 with only 30k miles. I got 2 engine code came out just today.
p228097 the air mass flow in the intake air system (cylinder bank 1) has a malfunction. system function is restricted
p222B84 Pressure sensor 2 has a malfunction. There is a signal below the permissible limit value
What do they mean and is it something that I can fix? I did not feel any power loss etc. I really do not want to take it to a mechanic as they really ask an arm and leg in Canada
I appreciate any help.
Old Feb 10, 2022 | 01:59 AM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
clear the codes, see if they come back.
check the wiring and connectors on those sensors if they do,
Old Feb 10, 2022 | 08:32 AM
S. Madman's Avatar
2012 E550 sedan 2019 E63 Wagon
Check your camshaft sensors for oil, search for my post. See if you have oil on the ECU.
Old Feb 10, 2022 | 12:13 PM
2012 E550 4Matic
I cleared codes and they came back. Wires look okay.
Old Feb 10, 2022 | 12:16 PM
2012 E550 4Matic
I had removed two camshaft sensors to see if they have new version (having green seal) and installed back. I got the codes 2 days after I did this. Cables, connectors look okay.
Old Feb 10, 2022 | 01:21 PM
Siegmann's Avatar
10-second E550
It may be the pressure sensor on the rear of the passenger side airbox.
Old Feb 10, 2022 | 02:02 PM
2012 E550 4Matic
I will check do you have schematic or part number?
Old Feb 10, 2022 | 02:37 PM
Siegmann's Avatar
10-second E550
P/N is A0071530528 for either side:
Old Feb 10, 2022 | 06:03 PM
2012 E550 4Matic
Thank you so much.
Old Feb 11, 2022 | 07:31 PM
Siegmann's Avatar
10-second E550
Thank you so much.
No problem. It's an easy DIY if that is indeed the problem. The reason I think that may be it: those sensors' outputs are compared to the post-turbo MAP sensors to give the computer a pressure ratio for calculating mass flow. When a sensor goes bad, the 2 sides read differently and you get a code.
One of your error codes refers to bank 1 (passenger side) and the other to sensor 2. I'm not sure if sensor 2 would be on bank 2, but it may be worth replacing both anyway.
Old Feb 12, 2022 | 12:58 AM
2012 E550 4Matic
Isin't that early for sensors to get fail as car has only 30k miles.
Old Feb 12, 2022 | 01:00 AM
2012 E550 4Matic
Is there any way to know if these sensors really went bad, Is it possible to measure them?
