Sponsored by: CARiD
Service codes
Old Feb 20, 2022 | 05:51 AM
gussy81's Avatar
W212 E Class 220D
Service codes
Hi,
I'm sure this has been asked plenty of times but I cannot find the answer. My e class is saying a b3 service is due. I have it booked in. Is there a list of these codes and what needs doing at each interval. So is there an explanation of each service code?
G
Old Feb 20, 2022 | 10:27 AM
RA72825's Avatar
Some say it means the 3rd B service. Others say it codes the specific items that need attention. I’ve had as high as a 9 (A9), but I don’t believe any of it. So many services are taken out of sequence like plugs, transmission, brake fluid, coolant, etc. which may happen based on years vs mileage I don’t think any of these A-B codes mean squat. You need to follow the maintenance schedule for your specific vehicle and keep your work orders so you know what has been completed. I guarantee if you ask the SA what those numbers mean they will give you a vague answer and then try to sell you something you probably don’t need.
Old Feb 20, 2022 | 01:52 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
For some reasons finding clear service scope is not easy, so get used to it. This is what I saved few years ago , so see how that can work for you?
File Type: pdf
Old Feb 20, 2022 | 06:16 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
I took the Mercedes service schedule for my 2016 E350 4matic wagon and reorganized and condensed it to this:
“A” Service at 12 months or 10,000 miles, then every 2 years or 20k (eg, odd 10k intervals)
“B” Service at 24 months or 20,000 miles, then every 2 years or 20k (eg, even 10k intervals)
Every 10k miles or year (A and B)
  • Read service data, reset ASSYST PLUS display (A,B)
  • Oil and filter change (A,B)
  • Check brake fluid level (A,B)
  • Check coolant level (A,B)
  • Inspect tires (A,B)
  • Inspect brake pads, rotors (A,B)
  • Check/correct tire pressure (A,B)
  • Check/correct spare pressure (A,B)
  • Check warning/function lights (A,B)
  • Check interior and instrument lighting (A,B)
  • Check horn (A,B)
  • Check washer fluid (A,B)
  • Check exterior for visible damage (A,B)
  • Check windshield for damage (A,B)
  • Check wiper blades (A,B)
  • Check first aid kit expiration (A,B)
  • Clean visible area of water deflector (A,B)
  • Check parking brake (A,B)
Every “B” (20k miles or 2 years)
  • Check exterior lighting (B)
  • Check wipers,washers (B)
  • Replace charcoal interior dust filter (B)
  • Check poly V belt for wear (B)
  • Check vehicle underside for leaks,damage (B)
  • Check tires for damage/cracks (B)
  • Check condition of steering, tie rods (B)
  • Check front axle and ball joints (B)
  • Check rear axle and ball joints (B)
  • Check spring/strut/shocks (B)
  • Check drive shaft flexible couplings (B)
  • Check power steering fluid (B)
Note, 30K service ‘A’ performed at 28770 by MB of Santa Fe
Additional work:
  • Replace brake fluid - every 2 years
  • Clean/Lubricate Panoramic Roof - every 30K/3 years
  • Replace engine air filter - every 50k/5 years
  • Replace spark plugs - every 50k/5 years
  • Replace ATF oil/filter - every 60k/6 years
  • Replace fuel filter - every 150k/15 years
