Rim Guidance
Product Specifications:Product ID: 85543
Fitment: Front
Material: Aluminum
Style: 10 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 20mm
OE Part Number: 21340140007X23, 21340140007X21
Product ID: ALY85544
Product: Wheel/Rim (Single)
Fitment: Rear
Material: Aluminum
Style: 10 Spoke
Lugs: 5
Bolt Pattern: 112mm
Offset: 49mm
OE Part Number: 21340125007X23, 21340125007X21
any advice would be appreciated 🙏🏼
also, a seller responded with the following:
The rears looks like they will fit for sure based on the offset The fronts I’m not sure how to get a good calculation based on reviewing wheels with offsets of your current year make and model compared to this one as this offset seems to be a little bit less with a 20 on the front That doesn’t mean it will or will not work I just don’t have an answer for you that I feel confident in telling you I think that’s the best course of action would be to contact a dealer As I’m leaving leaving the final fulfillment decision to you
Our offset and bolt pattern
Lugs: 5
Bolt Pattern: 112mm
Offset: 49mm
Lugs: 5
Bolt Pattern: 112mm
Offset: 20mm
Example of your 2014
Lugs: 5
Bolt Pattern: 112mm
Offset: 45mm
Lugs: 5
Bolt Pattern: 112mm
Offset: 46mm
Lugs: 5
Bolt Pattern: 112mm
Offset: 49mm
Lugs: 5
Bolt Pattern: 112mm
Offset: 20mm
Lugs: 5
Bolt Pattern: 112mm
Offset: 45mm
Lugs: 5
Bolt Pattern: 112mm
Offset: 46mm
I have a 37ET offset up front and a good 3-5mm of poke. A 20ET in front would stick way beyond the fender. It would look ridiculous and cause issues for you. Good luck
The best photo I have of my rear clearance:
2-3 mm spacer will still allow original flange to center the wheel.
Thick spacers will have grove for original flange and new flange on top of it.
the 5 mm is not thick enough for making that, while you loose the original grove, so avoid that size.
When I neve used spacers on MB, I did own several dually pickups and some of them have spacers in 6" (150 mm) size. Working just fine.
