VVT Monitor Banks 1 and 2 Fluctuation from Pass to Fail
I couldn't find any other test through the 40 or so I clicked through that were fails. No misfires, if I remember correctly, under high neutral revs I saw timing upwards of 30 degrees.
Under Xentry, we can test VVT actuators but there is no pass of fail. Because it is a simple maximum advance or retard depending which cam you are testing. Its an ON-OFF test so to speak.
NOTE: Alebit my engine is M276 3.0 and yours is a 3.5L assumed as M276 , the VVT system is the same.
If VVT fail, DTC is for sure triggered because if I remember correctly, 5 degrees drift is maximum.
NOTE FOR TEST : Some are bidirectional via Xentry, some are hands on we do physical check and guidance provided.
IF these above values drift too much, DTC is guaranteed. 5 degrees drift is equal to 1 timing chain tooth jump.
Take photo of your icarsoft test page, I am curious about it.
OBDII and Benz are the menus that give data relating to my car
Page 1 Inside of OBDII Menu
Page 2 Inside of OBDII Menu
Page inside of BENZ Menu
Inside of BENZ Diagnose, preceeds listings
Attempted to enter ECM menu and am met with this error. Received this error for other menus aswell. Not sure what the specific reason for no entry is, since I have no experience with this
Page 1 Benz Diagnose
PG 2 Couldn't see any of this relating to engine values, nothing in instrument cluster.
PG 3 All of these seemed useless
This and the preceeding image was the only remotely close thing I could find.
Same as previous image with different timing advance. Advance degree within normal specs?
VVT is timing of the opening of the Intake and/or Exhaust valve. https://en.wikipedia.org/wiki/Valve_...iston%20valves.
Ignition timing is taken from the computer memory based on a TABLE/MAP for fueling and other related data to make combustion as perfect as possible.
https://motorsport-electronics.co.uk...html/4100.html
Dynamically ignition timing can also change from input of the knock sensors to the engine computer telling knock exist and timing to be retarded. Engine Load will effect too.
This is a good explanation on Ignition timing and knock sensor
Wideband lambda sensor ( Bank 1 no 1 and Bank 1 no 2 oxtgen sensor ) also do last second fine tuning. Our engine combustion management is very fast and complex.
Ignition key need to be at position 2 ( ready to crank, dashboard all lights up or Engine OFF Key ON EOKO some people call it ) for ECM to be able to communicate with scanner, some modules do not need up to key position 2.
So, you got nothing to worry....
When engine still cold, the timing get retarded because engine need to be at encriched fuel mix and cylinder wall still cool, so flame can't propagate well, hence timing can not be too advance.
