Big Yellow Thermometer Graphic?
Does anyone know what this is? Sometimes it appears when the temp climbs a little and also when the temp drops a little. It frequently disappears after a few minutes of driving. The check engine light was just a loose gas cap. But the yellow thermometer continues appear.
That could be the car is not getting warm enough due to a bad thermostat.
Check, and see if an OBD scanner says p0128.
Codes might yield the answer.
