Sponsored by: CARiD
Random error messages appearing on board
Old Nov 15, 2022 | 04:42 PM
bilalelaly's Avatar
Class A
Hi all,
I have a problem with my Class A, 2014. It happened few times now, when I am driving I start getting 'PRE-SAFE Functions limited' message. Then suddenly, I start getting all errors randomly : EPS inoperative, park assist inoperative, Active bonnet inoperative, Park Break inoperative etc...Also the car starts to suddenly act unresponsive, sensors start flashing, whenever I put turn signal (left or right) I should put them multiple times in order to function, switching from D to R becomes irresponsive also and I should do it multiple times to function....
If I turn my car off, it won't turn on again. If I leave it for a day or 2, it works again very normal ! Then suddenly the exact same happens again. I visited the garage which passed the obd tests and they got no fault codes!
For info, whenever I try to turn the car on the message 'Anti-theft protection activated' appears. And I get 'Risk of rolling error...'.
It seems that the car is displaying all the errors on screen randomly...
Any idea what this could be? and how to approach this ?
Thanks!
Old Nov 15, 2022 | 05:06 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by bilalelaly
Whenever I try to turn the car on the message 'Anti-theft protection activated' appears.
I see you also posted in A-Class forum. Found this bulletin that may or may not be relevant although it does not reference A-Class it 'may' provide a lead. I suggest choosing a shop that uses Xentry (MB diagnostics) to erase stored codes & run quick test to pull current codes + provide diagnostic assistance.
File Type: pdf
Old Nov 16, 2022 | 10:17 AM
bilalelaly's Avatar
Class A
Thanks for your reply.
I managed to get the errors on odb please find below:
Old Nov 16, 2022 | 11:31 AM
'71 Pinto
See attached bulletin.
File Type: pdf
Old Nov 16, 2022 | 01:22 PM
S-Prihadi's Avatar
Water intrusion at CAN BUS distribution block is also a possibility.
If big rain been somehow related, well..................
Old Nov 20, 2022 | 02:54 PM
bilalelaly's Avatar
Class A
​​​​​​​Workshop tested batteries and alternator and said all is ok.
They say it's the ECU that is faulty and has to be replaced... I'm really confused and not sure about that.. Is what they're saying logical?
Old Nov 21, 2022 | 03:37 AM
S-Prihadi's Avatar
CAN BUS DISTRIBUTION BLOCK has nothing to do with alternator wiring.
Yes, very low battery charge can make the modules issue weird warnings/DTC
Get a proper scanner or MB Xentry, find out those DTC are issued by which modules ?
