Temp gauge goes 120degrees??
it also blows hot in my car and its not overheating 🤷♂️
As i parked, it went down to 80/90 really quick and when i just stood there, without motor going, it went up to 120 again, anyone have a clue?
dirty trick on that needle, if the actual temp is under 80C, its shown directly. if its between 80 and 115C, it shows a constant 90C. if its between 115 and 120C, it shows 95C. if its between 120 and 130, it shows the actual temp, and if its over 130C, the red light is lit.
see the attached two PDFs from WIS...
We know the gauge is a white liar but it is a downplaying liar to hide temperature spike up, but it is not design to scare you by showing 120C if it is not at 120C.
The cluster gauge is dummy gauge, showing you overheating after it already happened.
I drive with temperature display on my scanner and the cluster will show 90C, when actual temperature drops below 80C.
Than when climbing, the engine temp will go to 100C, when cluster still shows 90C.
Either way, what happened above is abnormal and need to be check.
