Sponsored by: CARiD
hey, anyone ever have their coolant temp go BELOW 80 during snow?
Old Jan 20, 2023 | 06:31 PM
shockandawe's Avatar
2016 Mercedes E400 4MAITIC
it goes back up to 80 when i get to traffic, but when it’s free driving it dips.
the car is a 2016 e400 sedan TTV6 running a tune
TIA 🫡
Old Jan 20, 2023 | 06:49 PM
DFWdude's Avatar
2016 E350 Sport
When driving in snow, I concentrate on the windscreen view, not the instruments.
That said, I've never seen my W212 temp drop below 85° although it's never been driven in snow.
Old Jan 20, 2023 | 09:26 PM
cetialpha5's Avatar
I don't know about the M276 but on the M272, the thermostats used to go bad all the time. My guess is that your thermostat is stuck open so it doesn't run as efficiently. A scanner might be able to tell you if you have a pending code or actually read the temperature.
Old Jan 20, 2023 | 09:43 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
TIA 🫡
seen it on mine as well, driving open highway after midnight 95+ MPH . However, once at the traffic light after the ramp it goes up fast
Old Jan 21, 2023 | 01:58 AM
cmon have to check both at all times, that being said, i’m paranoid about my car so i’m always checking everything all the time 😂
Old Jan 21, 2023 | 01:59 AM
i’ll do a scan and see what up just in case, but alls back to normal.
this is more reassuring since mine has also gone back to normal, i want to say it was because we had similar conditions (open road and cool air)
Old Jan 22, 2023 | 11:18 AM
S-Prihadi's Avatar
Dont rely on MB coolant gauge if one really wants to know actual coolant temperature. Its a white liar gauge
https://mbworld.org/forums/e-class-w...inda-liar.html
Old Jan 23, 2023 | 06:27 AM
oh wow this was useful thank you so much. very clutch information here
Old Jan 23, 2023 | 09:26 AM
DFWdude's Avatar
2016 E350 Sport
I'm not paranoid about my car. When it's snowing, I am paranoid about the idiot drivers around me who haven't a clue how to drive in the snow... so my vision is through the windscreen, not on my instruments. I'll just add that when snowing, I never exceed any speed limit, so no need to look at the speedo, either
Happy to finish my thoughts on this matter.
Old Jan 24, 2023 | 03:46 AM
S-Prihadi's Avatar
Last nite, took photo for fun to see the cheating the coolant gauge is doing
90C shown but in actual it is 102C.
Seemingly cooler by 12 Celsius cheat, damn !!!
Old Feb 2, 2023 | 03:27 AM
neat stuff here, i also found another video on youtube explaining this. thanks for adding on boss
Old Feb 2, 2023 | 10:01 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
Dash gauge is dummy gouge, so for it to show below 80C, the temperature had to drop down to 70C
I drive my diesels with monitoring scanners and having long downgrades on desert, the engines who normally operate at 85C will cool down to 78C.
The dummy gauge stays firmly at 85 however.
The above might be indication of thermostat closing too late, but without real gauge, we can guess endlessly .
Old Feb 2, 2023 | 10:49 AM
also noted. i do suspect it may be the thermostat. i’m buying one and i’m going to put it in myself as i’ve actually seen the needle drop to 50C (it was 22F/-5C) and that spooked me. we are expecting -2F/-18 and i don’t want to find out what the gauge drops to then 😵‍💫
Old Feb 2, 2023 | 11:54 AM
S-Prihadi's Avatar
It is easy to check if your thermostat is "leaking" or semi-open aka un-able to close maximum when engine still cold or maybe open up too soon on its own, or ECM command.
Mechanically the thermostat is suppose to open ( wax melting ) at approx 90C and upwards and this is without the heater assist and can be sooner if for some reason the heater assist in progress.
U will still need OBD2 based gauge as a true coolant temperature reader and if you have a thermal gun it will be nice, or you can use your hand as temperature sensor
to feel the hose at the thermostat housing output side, the one to the radiator.
FIRST UN-PLUG the connector for heater at thermostat R48. It is a 2 pin connector.
The heater connector you then connect to a test light or any 12V bulbs of no higher than 5 watts, T10 bulbs from your trunk side light is 5 watts .
This is to visually see, if your heater get any signal too early before 80C.
We need to exclude false triggering electrical wise and verify mechanical separately.
Mechanical
If say OBD2 gauge read 70C already, compare it to your Instrument Cluster one ( need a friend to assist ) , IF you by 70C to 80C OBD2 value can feel the the hose for heat, the thermostat is kinda "leaking" or opening too soon.
Old Feb 2, 2023 | 12:09 PM
S-Prihadi's Avatar
Here is at what temperature the heater is used to assist earlier opening of the mechanical thermostat and 95C is when mechanically the thermostat will open itself maximum
https://mbworld.org/forums/e-class-w...mperature.html
Old Feb 6, 2023 | 07:01 PM
Just an update all, it was my thermostat, i changed it out and my temp is back at the 90-95C range. thanks for all of your input and brainstorming with me 🫡
