Oil Temp Sensor | Crankshaft Sensor
Hi,
Engine: 250CDI (651924)
Year: 2010
Experiencing limp mode recently - so I read the codes and got the below:
I also got these codes form the COMMAND system
Year: 2010
- P246397 The soot content of the diesel or gasoline particulate filter is not OK. The system function is restricted.
- I suspect this is cause by the below - I'll do a force regen once I've replaced the intake pipes.
- P227985 A leak was detected in the intake air system. There is a signal above the permissible limit value.
- I've found a split in the intercooler pipes
- P019664 Engine oil temperature sensor 1 has a malfunction. There is an implausible signal.
- P033900 Position sensor 1 for the crankshaft has a sporadic malfunction.
- 9468 Speaker channel 2 has an open circuit.
- Is channel 2 the passenger front on a W212?
- 9422 There is an internal fault in the CD/DVD drive.
- Assuming this will be a replacement if I want to fix?
chassis (02-26-2023)
Received 3,994 Likes
2017 GLE350 4MATIC
Hi,
Year: 2010
Year: 2010
Buy only OEM MB parts from the dealer for this.
Lee_ (02-27-2023)
Received 1,747 Likes
1922 Ford Model T / no OBD
Oil temp sensor usually is pigyback on level sensor, so look on the side of oil pan.
As for DPF, do you have monitoring scanner? What's the % ? and how old is it?
I think oil temp malfunction can prevent DPF regeneration ,so do it ASAP as DPF filled above 200% will bring you lot of additional headaches.
