Radar Sensor Replaced
Just had my radar sensor replaced, thought I'd come to this forum as it's much more active than C218. My left rear one died, and I got it replaced, and the blind spot sensor is working again. I am having issues with the lane keep assist features though. When my car goes over a broken white line, there is no steering wheel vibration thing to alert me that I'm moving out of my lane (obviously doing this on purpose to test the feature without signalling), and for solid lines (going over 60kph because that's the minimum speed to activate this), it does not work either. However, I realized when I turn the features from sensitive to off for lane keep assist, and then back to sensitive, it starts working again. I believe I have to turn off some other stuff too and turn them back on for this to work. I'm not sure if coding was required after my mechanic installed it. Every time I shut the car off, I have to do this all over again to get the lane assist settings to work again. Keep in mind, that all the settings are set to sensitive, they do not turn off, but even when they're on sensitive, they do not work until I turn it off and on again.. It was not like this before when the old radar sensor was functioning correctly.
Blindspot is always working btw, it's just the lane change that's acting like this.
Drive the same section of E-W highway in the morning, then in the late afternoon (drive the same direction), and you should see some differences, due to sun angle.
It will seldom work at all on rain covered roads, because the sheen everywhere on the road disguises the lines compared with the rest of the surface, if that makes sense. Of course, when it's raining, I don't rely on LKA at all.
Just as your eyes can be deceived by changing lighting, so can this technology based on the same visual spectrum. So, I am not too worried when Lane Assist works inconsistently.
Beyond that I'm stumped. If the camera works at all (it does intermittently) then it's not the camera itself, but something that powers/controls the camera. An OBD2 reader might be able to pull codes related to the camera.
