Sponsored by: CARiD
Water ingress no Pan roof
Old Mar 21, 2023 | 09:15 AM
jajcek's Avatar
2011 W212 E220 CDI
Hi all
My 2011 W212 E220 CDI Avantgarde Saloon developed water ingress in the place where head liner is joined with A pillar. I would blame clogged sunroof drains but ....my car doesn't have Panoramic roof so I don't really know where water comes from I found an entry on mbworld.org however it doesn't really give me any directions in how to fix it ( below )
I bet it leaks at the junction between the A-pillar and the roof. It is built with only couple spots welds to help absorb frontal crashes. A joint compound is applied to seal this loose seam but given enough stress it cracks and shrinks!
The roof lateral discharge then pours straight inside
  • strip A-pillar interior trim to see water coming in (you really want to minimize water damage by pouring as little water as necessary)
  • Use a water hose around windshield sides then top horizontal then last on roof to test pillar seams. ie test spray the lower parts before the high ones'
Any of you members experienced similar issue on 'non panoramic roof car' or have advice how to fix it ?
I doubt there are any water drain tubes as it doesn't have sliding roof?
Any help would be greatly appreciated
Regards
Jack
Old Mar 21, 2023 | 11:57 AM
konigstiger's Avatar
'71 Pinto
If you have not already done so lower front headliner for visual inspection to identify entry point.
Old Mar 21, 2023 | 01:55 PM
jajcek's Avatar
2011 W212 E220 CDI
Thanks for your reply appreciate it
Could you kindly point out the points to check , im not sure what to look for....is there anything behind that piece of 'cardboard' that can let water in or above airbags?
thanks again
Old Mar 21, 2023 | 02:11 PM
'71 Pinto
Goal here is to identify point of leakage may be migrating to a-pillar/headliner location lowering front portion of headliner up to overhead handles will provide access for visual inspection. In addition, you can remove exterior drip rail on affected side that acts as a drainage channel, same procedure without pano or sun roof.
File Type: pdf
Old Mar 21, 2023 | 02:27 PM
jajcek's Avatar
2011 W212 E220 CDI
Wow. That's awesome thanks for PDF . TBF today before I got to
work I've removed that plastic trim on the roof , and there are two points to install roof bars. Before I take half of the interior down , is it possible that it leaks from there ? Looking at the position of roof racks mounts and where leak appears inside it would make sense...Thank you very much for your response
Old Mar 21, 2023 | 02:37 PM
'71 Pinto
Your call but if it were me I would want to identify moisture point inside then proceed to coordinating exterior location.
Old Mar 21, 2023 | 03:36 PM
jajcek's Avatar
2011 W212 E220 CDI
Thanks for your help. I hope weather improves so I can start stripping it down. For the mean time time a applied some tape over roof trim , hope it's gonna temporary help. Once again thank you for your help
