CV AXLE BOOT
First; a wish for a happy/healthy holiday to all and family.
I have not posted on the site for quite sometime but I am so very thankful for the guidance I received from so many members when I queried to sell my car or buy a new car after the extended warranty ended.
With the forum help I kept my 2014 MB E350 4MATIC (Model212) and I still love this car from the day I bought it in October 2013.
The car is at 105K MILES and with thankfully no issues; only ordinary maintenance....tires; battery; A+B scheduled checkups as per the manual LIKE CLOCKWORK---I NEVER MISS.
I placed four new tires yesterday and was shown that the boot cracked and the oil/grease was not encased on the LEFT FRONT AXLE.
I NEVER HAVE HAD ANY DRIVING ISSUES, NOISES; ETC and I would never have known of this issue unless I did the tire replacement.
My question is:
Do I go to a MB dealership or find an indie and ask to just replace the boot or replace the entire unit. What price area would I be looking at and what is the usual number of hours to perform such a repair.
I truly appreciate any advice and/or suggestion.
THANK YOU !!
My W212 is not 4M, but I did boots on W210 and W211.
Could buy German-made boots for $40 in the past, while MB boot for W211 was about $100.
This is about 1 hr job even for DIY.
I made pictorials about those jobs on benzworld,
But since you drove the car with lost grease, make sure the joint is still in serviceable condition.
My question is:
THANK YOU !!
Is a re-boot procedure in the WIS? Seems like it should be in there even if the dealer "won't do it", if Mercedes sells the boot kits...
Thanks.
Thanks.
Disassembly went very smooth until the inner CV joint. My inner boot was torn so as soon as I removed the bolt and pounded out the outer joint the axel came right off. Cool, (I thought) I'll heat up the inner spline joint connecting to the intermediate axel and tap it off with a hammer and chisel. Um, nope it did not budge. I got out a slide hammer and heated the connection as much as I could. As I'm hammering away with the slide it finally comes loose or so I thought. What happened was that the intermediate axle shaft and bearing which is held in place with a snap ring behind a flange on the transmission housing BROKE!! Yikes...I was seeing $$$!! So, I have the intermediate axle and CV axle(inner joint housing) still together but off the car. I kept trying for the rest of the afternoon and I couldn't get it to budge. It is still together to this day. It's about an inch too long or I would machine it off with my lathe to assert my dominance.
I quickly ordered a new intermediate axle and bearing from FCP Euro and started brainstorming solutions to the broken flange and retaining clip problem. Ultimately I was recommended trying Loctite 620 bearing and sleeve retaining compound by a close friend. Just clean everything up and apply to both surfaces and assemble. Thats, exactly what I did. Reassembled the CV axel, air strut and good to go. I'm actually kind of shocked it worked as well as it did honestly. 20/20 hindsight I should have just planned on replacing the intermediate shaft along with the CV axel. The bearing was toast anyway. The dealer wanted $1500 for the CV axel plus labor. So, I guess I made out well considering. However, my left headlight went out the next week to the tune of $3200?!?!? I guess it always evens out. Still love the car and it gets lots of smiles per gallon.
Good luck!
Took the axle and the boots&grease to them, picked it up the second day, when I was picking it up he mentioned that they only did it because it was the original axle, they wouldn`t touch an aftermarket stuff. Drained and changed the diff fluid as well since I was there, also changed the seal. So far so good since January 2024.
I have used GSP from RockAuto for my wife`s 2008 Infiniti about 2 years ago and still holding up pretty good, no vibrations, no leaks or tears. After reading so many comments about MBs dont do well with the aftermarket axles and since I caught it pretty early, I did not bother with aftermarket.
Also have an X164, both fronts have slight wetness for a while now, probably I`ll tackle with that in coming summer.
Thanks.
I think I'm going to do brakes, brake lines, brake fluid, axles, lower control arms, and front diff fluid all at once. Will replace the center drive shaft as well if it looks like it's probably better than what's in the car.
The retaining ring on the inter-shaft blocks the cv shaft goes in. Without the ring it can easily slide in and out but not with the ring. I just can’t push it in.
I am thinking to not put on the ring and don’t know if that’s ok.
thanks for any input.
Only advise I can think of when installing the axles back is to grease the sealing ring then it should fit right over.
The replacement part #'s are easy to find. The boots have the MB part #'s stamped right on them. The clamps are stamped with there size on them. Clamps are Oetiker. Or you can get them off the parts diagrams. I looked on the W212 diagrams and seems they only show the part# for the boot kits and not the separate parts. This is the same as the W204. But the diagrams for the W221 show the separate part #'s. It appears the W204, W212 and W221 use the same parts.
