Issues after replacing airmatic valve block
I could use a little help. I replaced the airmatic valve block to fix a leaky system. The front end would be on on the ground after about 3 days of sitting. I got the valve block replaced yesterday without any real issue. The car appears to be at the same height as it was yesterday. But on a brief drive this morning it is apparent that something is wrong. The rear end feels unstable going over bumps and I’m also getting some rear end rattling, even though I did not touch any other suspension components. Any thoughts on this? I’m going to jack it back up to see if I can find anything but all I can think of is maybe something came loose when all of the air was deflated from the bags.
Meh, found the issue. Like I had suspected, the air spring collapsed and came out of its mount when it was fully deflated. Luckily I only drove it for about 4 minutes and didn’t get above 35mph taking my kid to his bus stop this morning or that could have been bad.
The following 2 users liked this post by RDE38:
pierrejoliat (05-23-2023),
Raj1471 (05-22-2023)
it was the right rear so luckily it was the easiest line to access again on the valve block. I opened up the line to let it deflate and was then able to realign the bag into place. Then after I reconnected the line again I started the car and lowered the Jack a bit to get the pump to turn on. Then I was basically able to hold the bag in place as it pressurized and snapped into place. I bought one of the $70 blocks on eBay. Most reviews I found people were using this one instead of the $300 oem one.
