Maintenance Issues (plugs, coils)
https://www.fcpeuro.com/products/mercedes-spark-plug-kit-bosch-0041598103-kit-iskm278a
Mechanic said the ignition coils didn't look like the factory ones so he skipped doing those and that I "didn't need to worry about them." I have my car back now and it's idling SUPER rough. I assume he didn't index the plugs properly so I'm bringing it back tomorrow. With that, 2 questions:
1. He already did the plugs, is it a big deal for him to go back and swap the coils at this point? I want to use the new ones I bought not the ones with 100k miles on them. That's also what I paid for.
2. Can someone confirm these are the right coils (I believe A2761590542)?
Thanks!
VIN is WDDHF9BB2EA941414
https://www.fcpeuro.com/products/mer...3-kit-iskm278a
Thanks!
Just an FYI, these are just the connectors and not the actual coils. So if the coils themselves are bad, replacing only the connectors will not fix anything.
I believe they do have a larger 'ignition service kit' that includes coils, connectors and plugs all in one, or maybe I'm mistaken.
Either way, at 100k miles if I was about to get a tune or any sort of performance mods, I'd definitely get new coils and plugs and maybe even replace the HPFP just as preventive maintenance.
Hopefully the plugs and coils won't be too crazy to swap, seems like he already did the brunt of the work. Although also sounds like he's going back in to address indexing at this point (or something else).
I brought up the indexing thing again and he insisted its not a thing. That if you use the exact same size spark plug, and torque them to the correct spec, that there is no need to do anything else. He also said its not possible to monitor the indexing on these M278 engines as you cannot look down into the area where the plugs go on this setup since everything is so tight. Does that sound right to folks? If not, I'm probably going to a new mechanic to have the indexing double checked, I know not doing that right can lead to big problems.
I have the new spark plugs, camshaft sensors/magnets, and sacrificial harnesses all installed now. Also just did a full transmission service (filter, gasket, fluid). This thing is ROCKING, drives freaking amazing, I can't believe this car can be had for low 20's.
https://www.ebay.com/itm/11569995064...mis&media=COPY
Did you install the new plug wires with ease? Same part number as above? My mechanic was baffled and said the new ones (new part number compared to what was installed at the factory) didn't "fit right" and were next to impossible to get in.
the other trouble I ran in to was getting the wires/connectors off of the coil packs. I had to fidget with them quite a bit bit eventually they came.off.
Did you share the threads of owners requiring engine rebuilds possibly due to burnt cylinders due to poor indexing? Was the shop willing to write on paper that they are willing to replace your 80k dollar engine if it burns a cylinder, or will they blame a tune or something else. And im not talking about the standard 12k mile one mile warranty. No offense, but if this mechanic will not correctly install parts according to mercedes maintenance documentation and advice, you need to stop driving the car and take it to a mechanic that is willing to do the required work. IMHO, I would not just drive on it till the next interval as you may kill the engine. Next time a mechanic tells you he doesn't believe in a factory document, its time to leave that shop and go elsewhere. Dont start with that shop or you will waste time, and possibly waste your engine. Start with a shop that agrees to do whatever you ask to pay for. Theres no need to ever argue with someone you are paying to provide a service, and its definitely never worth the savings and can often cost more in the end when all time and money and frustrations are considered. Some shops would hate if you shared the KENNYED video of how to properly index, and others would be thankful for you saving them time and money. Stick with the latter. Good luck.
