Sponsored by: CARiD
RADIO, COMPONENTS and BLOWER FAN going in and out constantly
Old Sep 21, 2023 | 11:48 AM
JBE350's Avatar
2010 E50 W212
2010 W212 E350 4Matic. Recently a had water leak on the rear passenger side on the carpet floor. Ater driving i noticed the radio, instrument buttons and blower fan was going in and out. Now engine light is on, and everything going in and out constantly.
Trying to find the cause of this issue and
Would like to know what the solution or if it's possible to reset those components?
Old Sep 22, 2023 | 03:34 AM
ygmn's Avatar
2015 E400 Sedan
where did water leak come from? you state where it ended up but where is actual water getting in?
Does it run on any modules or harness connectors?
Did it get under front seats?
My guess is a module got wet inside and is getting funky due to water shorting connections inside.
Old Sep 22, 2023 | 10:20 AM
JBE350's Avatar
2010 E50 W212
I know water been leaking from the right side of the trunk right under the rear windshield in that corner... but .. also they said that water leaked from the sunroof (i did not know that was happening).
and .. No. water did not get to the front seat or carpet.
Question: do the 2010 E350 have plugs, harness or modules under the rear right-side carpet? Or inside right-side panel?
Old Sep 23, 2023 | 05:59 AM
ygmn's Avatar
2015 E400 Sedan
I am sure there are modules under rear package deck...
go in trunk and look up under this package tray for signs of water...
my guess is it ran down wire into connector on module and messed stuff up.
ALso get codes read from all modules...not just ECM.
Old Sep 23, 2023 | 03:19 PM
JBE350's Avatar
2010 E50 W212
Ok. I look at the fuse box in the trunk, i dint see no sign of water.
I'll try to fallow the wires to see if there any water under or around it.
Let's see what happens .
