replacing brake shoes and rotors
you are doing the job solo.
Since the cost is low for that Motive brand of pressurized bottle, I suggest go for it.
I have one too.
I usually flush to at least 1 liter first and then use approx 500-700cc more as the true filling up from second bottle.
If no pressurized bottle auto-filling, to do 1.5 to 1.7 liter worth, we need to top up at least 6-7 times manual way. No fun.
Regardless if I plan full fluid flush, or not, I never push contaminated fluid from brake cylinders up to the ABS module and MC.
Starting the job, I loose the bleeder, put drip pan under and push the cylinder piston (often via old pad), letting the fluid to drip outside.
Just keep rechecking the reservoir lever to avoid air.
For full flush, using BMW cap with hole in it, I build a system who is using spare tire pressure to push 30 psi into MC.
I mean it is not full flush, as not opening ABS with scanner, I still have some fluid trapped there, but so far it works for me with no issues.
However, there is a bi-directional control menu, I forgot the name of it, which actually make ABS pumps rumble.
There is an aftermarket diagnostic tool seller which made a small circuit board or module to fool our ABS into actuation....while on a lift / jacked up all 4 wheels.
I dont know if it will work on our W212 or not, but this is how they do it :
The wheel speed sensors on our W212 is to be all 4 of them disconnected.
We then connect the wires for the sensors to their module, these 4 sets of wires from the module will generate signal of the same type like our wheel sensors and will create a bogus
lock-up condition, so that ABS is then forced to actuate itself. Something like that.
Also to note, our hydraulic brake is a one way fluid flow only, hence a single pipe/hose to all brake calipers and not twin pipe/hose. It is not circulated one like say power steering.
The dirtiest fluid will be the first 50cm of front brake calipers internal pipe, as it work the most....based on my car.
I say dirtiest is not black dirty, but the nice light amber of the MB brake fluid gets a darker yellow from the heat.
If master cylinder brake fluid reservoir in them can get dirty visually, that means the car owner is TRULY DIRTY & LAZY, and the brake fluid reservoir cap or its seal maybe loose too and
allow ambient dust/dirt to enter.
It is to be near invisible clean ( using MB genuine fluid ) when we try to see the brake fluid from side view of the reservoir.
If the reservoir white plastic body has aged and become a tiny bit yellowing, that won't help to see the brake fluid color
