Sponsored by: CARiD
2014 MB E550 4matic different tire size
Old Dec 26, 2023 | 10:03 PM
Andrikyo's Avatar
2014 Mercedes E550 4matic
Hi! Just recently bought my 2014 Mercedes E550 4matic. It has 19r wheels on it. The sticker on a driver’s door says that tire has to be 245/40R18 for both front and rear. I have the 245/35R19 for the front and 275/30R19 for the rear though. Will it affect the transfer case because of the different tire size, and the speed of front wheels will not match the speed of rear? I don’t have any ABS errors on a display.
Will attach a few photos of tires as now
Old Dec 26, 2023 | 10:15 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
For proper tire match you suppose to go to tire manufacturer site and find rpm for each tire.
General knowledge says you can have rpm mismatched by 3% before lights start flashing.
Usually CC is the first to act, disconnecting at 60 mph.
Old Dec 27, 2023 | 05:31 PM
CastorTroy's Avatar
2014 E550
1.2% difference in diameter. for reference, the stock 2016 e63s tire sizes are 255/35/19 and 285/30/19, which is also a 1.2% difference in diameter.
Old Dec 28, 2023 | 01:16 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
those /30 and /35 tires likely have a VERY harsh ride on rough pavement, cracks, railroad tracks, etc.
Old Jan 16, 2024 | 01:13 AM
ColonelKlink's Avatar
2014 E550 4matic 180k Mi
When I acquired my E, I liked that I had 245s (like your fronts) all around. During brake pad maintenance, I discovered that the rims were staggered. This results in a similar situation to yours, non-identical rotation. No error codes.
Update your geography profile when you get a chance for better assistance from Forum members.
I just repaired my front cracked rim. I think your sticker PSI listed is for 'heavy load' situations. I run MB 'normal' settings that are softer due to road conditions in my area. YMMV.
I like the fender badge and overall setup. Congrats.
Old Jan 16, 2024 | 08:13 AM
Andre Cateb's Avatar
W212 (212.065/276.820)
You have about 7 mm difference in the diameter which isn't really significant enough to cause any problems. Whether running staggered tires on a 4matic makes sense from a dynamic stand point them it depends on how the central diff splits torque to be honest. I've heard that the E63 has a rear bias on the torque split so the car can drift. Maybe the E550 has a similar set-up. In any case, the car looks great with those wheels.
Old Jan 18, 2024 | 11:22 PM
mgiara's Avatar
2013 Altima, 2011 E550
Is it okay if you just use the same wheel and tire for all 4 corners?
Also, spacers or not doesn't affect this right?
